Cisco SNMP/External Checks
  • jonnjonzzn
    • Sep 2007
    • 18
    OK, I am trying to pull active connection information from a Cisco (ACE) Load Balancer. I really only want the # of active connections to each back-end app server. I could not get a snmp check to work as has been discussed in this fourum as the "value #2 has unknow type [81]" error and also at https://support.zabbix.com/browse/ZBX-55
    So, for now I figured I just do an external script and pick off the data that way however I can not get an "external check" type item to work. Here is what I have done:
    1 Verified external script directory in zabbix_server.conf file is /etc/zabbix/externalscripts is correct and all permissions are correct.
    Have script named checklbload.sh with correct permissions in correct directory. Have restarted server and agent.
    ls -al /etc/zabbix/externalscripts
    total 16
    drwxr-xr-x 2 zabbix root 4096 Oct 10 15:35 .
    drwxr-xr-x 3 root   root 4096 Oct 10 12:08 ..
    -rwxrwx--- 1 zabbix root   21 Oct 10 14:31 checklbload.sh
    Here's the script code I'm using just to test::
    #!/bin/bash
    exit 50
    Created item in Zabbix for Zabbix server as External Check with key as follows: checklbload.sh[] with type as Numeric (integer 64).
    Here's what I see in zabbix_server.log:
    824:20071010:153722 Script /etc/zabbix/externalscripts/checklbload.sh returned nothing.
    824:20071010:153722 Parameter [checklbload.sh[]] is not supported by agent on host [wraith] Old status [0]
    Can anybody please help me?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    exit 50? Why? I would use "echo 50" instead....
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jonnjonzzn
      • Sep 2007
      • 18
      Ah yes, check the obvious things first... sorry. Changing to "echo" solved it.
      How about the first issue referenced above though
      I'm looking at checks_snmp.c to try and track it down but my C skills are rather rusty.
      Thanks, Alexei!
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        I'd love to repllicate this problem! I tried hard with all SNMP devices I have (a couple of switches, firewall, printers, etc), no luck so far.
        Alexei Vladishev
        My Twitter
