Help with Remote Monitoring Please
  • BigBirdy
    • May 2006
    • 25
    I have he zabbix server running inside a network (192.168.x.x) which uses an external gateway of 204.244.111.111 so that all outgoing connections will appear to come from that address. The external address of 204.244.222.222 has been setup to forward all connections to 10050 and 100051 to the Zabbix server at 192.168.x.x. I can connect to the internal server remotely, just fine.
    The external/remote Linux client has an external and routable address and is outside the firewall at 204.244.333.333 and since it is a hosting environment with multiple IP's the zabbix_agentd.confd is set to bind to 204.244.333.333 and to use "Server=204.244.222.222", I have also tried setting this to "Server=204.244.111.111" but I keep seeing the errors below from the zabbix_agentd.log on the remote linux client?
    5418:20071011:110852 Listener error: Connection from [204.244.111.111] rejected. Allowed server is [204.244.222.222]
