Update 1.1.6 to 1.4.2 _ mysql update problems
  • stkr
    • Feb 2007
    • 18
    I try to update zabbix from 1.1.6 to 1.4.2.
    I habe installed the new version. Now I want to upgrade the mysql database.
    But there are mistakes.
    - "Table action_tmp already exists"
    - "Table operations already exists"
    I read that you can drop this tables. So I did this. But now there is a problem that I found in another thread here:
    When I apply /upgrades/dbpatches/1.4/mysql/patch.sql from 1.3.6 or 1.3.7 distribution it show this error:
    ERROR 1054 (42S22) at line 38: Unknown column 'source' in 'field list'
    This line is:
    insert into actions_tmp select actionid,actionid,source,0,status from actions;
    Column 'source' is missing in actions_tmp and actions.
    I have the same message. Is there a patch for this? How can I fix it?
    Regards
    stkr
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    The upgrade script is not supposed to work with non-standard ZABBIX database schema. There are no tables action_tmp and operations in original 1.1.x database schema.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • stkr
      • Feb 2007
      • 18
      Hi Alexei,
      I think there is a misunderstanding, so I`ll try to explain.
      After i make the install of the new 1.4.2 Zabbix version, I use this syntax to upgrade the database.
      Shell> mysql --user=xxxx -p < patch.sql
      Then there was an error message, that there is a wrong syntax in SQL Script with the word "serial" ... So I search for this in the forum and find the solution, that this should be replace with "bigint unsigned EFAULT '0' NOT NULL" ..
      After this change, I`ll try to patch the database again. NOW the message from my previous post take effect.
      In the patch.sql of 1.4.2 there is a "Create Table" for the tables "actions_tmp" and "operations", so I think these tables are created before the "serial" - error code was triggered.
      So I think I must drop these tables, so that the patch.sql could be effect now. But then the following message is triggered:
      This line is:
      When you say that the tables actions_tmp and operations are non-standard of zabbix - why you create this tables in the upgrade patch.sql?
      When these new tables are correct - then there is a mistake in the insert lines, like:
      or
      insert into operations select actionid,actionid,actiontype,recipient,userid,subj ect,message,scripts from actions;
      because in actions_tmp and operations there isn“t a column source or actiontype.
      The attachment shows the patch.sql from the upgrades/1.4/mysql -folder
      So what I must change to upgrade my database.
      Thanks for help
      Best Regards
      stkr
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        The patch does not support multiple executions.
        I mean non-standard for ZABBIX 1.1.x.
        Alexei Vladishev
        My Twitter
