Agent not responding when host busy?
  • gryphius
    • Aug 2007
    • 30
    last night me (and my boss ) got woken up at 4 am because of a "zabbix agent nor responding" alert. We use {tmpl_agent_important:agent.ping.nodata(300)}=1 as alerting trigger (send sms if no data for 5 minutes, agent.ping is checked every 30 sec) .
    It seems that the agent did not return any data for about 7 minutes. At this time, the monitored host was unter load, doing logrotates.
    Has anyone had similar problems with Linux agents? (I've found similar threads, but all talking about windows only)
    Could you give advice on how to work around this false positive? I don't just want to disable alerting between 03:45 and 04:15 because I fear I could miss real alerts. Any better options?
    Environment: Zabbix 1.4.2, Server Centos 5, Agent Centos 4.5
  • rts
    • May 2007
    • 54
    We've got similar problems. Certain servers are rotated out of production to do processing tasks, and we know they're going to be heavily loaded. However, Zabibx reports them as being offline, when actually when we know they're still online, just a bit busy. What's the solution here?
    • oliverm
      • May 2006
      • 155
      Same here. We have a client with a ropy old web server. A couple of times a day they have it do something (zip up logs before downloading, unzip some large client upload) and the alerts go off.
      Problem is, we have learnt to ignore them, which is worse that acting on them. I'd love to find a solution.
      Olly
      • gryphius
        • Aug 2007
        • 30
        As I can't actually ignore my mobile ringing at 4 am I have increased the timeout until zabbix sends a sms. But this is just a workaround I'm not really happy with. Anyone got a solution that solves the real problem, eg. zabbix not responding?
        • oliverm
          • May 2006
          • 155
          Thinking wildly here. If the server is over loaded just before it stops responding, could you perhaps set a dependancy on the alert/trigger so that it checks to see the last value of the CPU usage ?
          • nelsonab
            • Sep 2006
            • 1233
            Try changing the "nice" level for the agent process so it has higher priority than other other processes. This may improve the changes that the agent will receive a slice of the cpu when the Zabbix server tries to connect with the agent. I don't think the agent is able to set it's nice level as of yet so it will have to be done manually. I haven't played with nice much lately and my brain is a little fuzzy so a quick education about renice would be in order before you use it. :-) Top can also change the nice level, but don't set it too low or your computer may be unresponsive.
            RHCE, author of zbxapi
            • rts
              • May 2007
              • 54
              One solution
              I've managed to stop receiving alerts by changing the UnreachablePeriod in zabbix_server.conf from 45 seconds to 180 seconds. My understanding of this parameter is that the host is demed unreachable if no items are returned within this time period.
              If my understanding is wrong, then I'd love someone to correct me. However, it does seem to have the desired effect.
