Negative Values
  • zabby
    • May 2005
    Negative Values
    I have installed Zabbix 1 and using it to query telecom equipment using SNMP V1. One equipment is sending a negative number (-45) and zabbix shows that number as a large number. The value is a 32 bits integer.
    Everything else is working excellent.
    Thank you to all the designers.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    If you have time, please check if the issue still exists for 1.1alpha. I think it has already been fixed.
    Let me know if you need a patch.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • zabby
      • May 2005
      Thank you Alexi.
      I am using zabbix in production system and can not update right now.
      I would set up a test system later.
      Yes, please send me the updat.
      Thank you very much.
      • Neo
        • Jun 2005
        • 59
        Where can I too get that patch for 1.0?
