Web Monitoring
  • RobertS
    • Aug 2006
    • 57
    Web Monitoring
    I want to monitor several very equal webservers in my farm (50+). Currently I do this with an "External Check" on a template that i use for all the webservers. So the script is called with the servername as parameter and it checks for a page that is equal on all webservers.
    Can I use "Web Monitoring" in 1.4.2 for this and how? I dont want to define a scenario for every host, because they are changing very often. I woluld need a variable for the host to be used in the url of the step and the possibility to assign the scenario to a template. I can not find any hint how to do this; is this possible?
    Thanks,
    Robert
  • scj
    • Oct 2007
    i have same problem. i want to to monitor 3o+ servers, but when i add webcheck to template zabbix agent, linked with this template, wont return values. if i add it one by one it works. looking forward for solutions.
    scj
    • mucknet
      • Dec 2004
      • 59
      scj
      FWIW - I'm getting the same results. I'm also unable to use the macro IPADDRESS, or HOSTNAME in the URL portion of web scenarios.
      I am however able to configure web scenarios for individual hosts, using specified ip's, or host name's.
      I will go ahead and file a bug at http://support.zabbix.com
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        This is not supported currently. Also, WEB templates are not supported yet. I expect lots of improvements in 1.6.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
