I have a question.
I have configured the eventlog function, with this tutorial
Thank you cstackpole for your investigations. Based on this, here is an example (cookbook) for everybody also struggling around with eventlog:
-) the source is "W32Time"
-) the description contains "synchronisiert"
-) the trigger goes off after 30 seconds
-) the eventdetails should be reportet in the mail
1) Create an item
Type: ZABBIX agent (active)
Key: eventlog[System]
Type of information: Log
2) Create a trigger
({mypc:eventlog[System].logsource(W32Time)}=1)&({mypc:eventlog[System].str(synchronisiert)}=1)&({mypc:eventlog[System].nodata(30)}#1)
you can add "logseverity()" the same way
3) Create a action
Condition: Host = mypc; Trigger value = ON (when you only want one message)
Message: {mypc:eventlog[System].last(0)}
So my problem is, that i get an e-mail notification with body "*Unknown*".
Why doesn't it work.
1) Create an item
2) Create a trigger
3) Create a action
