Hi there,
I want to use the web monitor function. However it doesn't seem to be working. Probably because libcurl is not installed. Curl however is installed, but configuring zabbix with --with-libcurl gives the error:
checking for curl-config... no
configure: error: Not found Curl library
The problem is that there is no libcurl package for fedora. Does anybody know how to do this on Fedora?
Thanks,
Roger
Thanks,
Roger
