I have zabbix monitoring about 112 hosts, with a total of 1300 enabled items. most of these items have an interval of more than 60 seconds (maybe 20% of 1300 items is at 30 seconds or less). I went through the posts relating to DB tuning and eventually I changed the DB/Table type to MyISAM, this did make a difference, but my Disk IO is still very high.
My server is a dell pe860 with a Perc5 Raid controller and 2 SAS disks (15k RPM) in a mirrored configuration. I'm running Fedora 7 64 bit on this host (the opne source drivers for the disk subsystem was developed by Dell, but it is community supported only).
My concern is the iostat "await" (or iowait in top) that seems to be running between 40% and 60% most of the time (this changed by about 10% less when I changed the DB from InnoDB to MyISAM, I actually expected much more of a difference). This machine is doing avg of 1.0 MB wrights per second (this number was about 6 MB when it was with InnoDB).
Is it a problem if the iowait is so high? The MB written per second is kind of low (I think ) for a DB applications that adds a couple of hundred records every minute.
Any ideas on this issue? I'm rather new to monitoring the Health of a server in terms of disk IO.
