Basic Graph Configuration
  • hornet
    • Nov 2007
    I am setting up an evaluation install on a Mac OS X system and have run into a problem that I did not see covered in the manual. I created a host and two items then tried to create a graph. When I hit the Add button next to Items nothing happens. Is there a log that I can check or some basic setup examples that might show a step that I missed?
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    What browser you are using?
    Zabbix | ex GUI developer
    • hornet
      • Nov 2007
      I normally use Firefox but I was also able to reproduce this problem using Safari and Camino.
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        FrontEnd supports IE6,IE7,FireFox & Opera.
        What version of frontend you are using?
        • hornet
          • Nov 2007
          I am using vervision 1.4.2 obtained from zabbix.darwinports.com
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            I don't have Mac OS X, but on WinXP on FF(v. 2.0.0.9) with FrontEnd 1.4.2 i've been unable to reproduce that problem..
            I think that problem in javascript(the way browser processes it), so if you want go farther: in FF in Tools-> "Error console", clear it, than push "Add" button see what's written in Error console.. Post it here if there is anything and i'll try to figure out what's wrong
            • hornet
              • Nov 2007
              I see this error in the error log from FF 2.0.0.9 on the local host.
              Error: PopUp is not defined
              Source File: http://crash.local/zabbix/graphs.php?form=Create+Graph
              I accessed the server remotely from a WinXP workstation also with FF 2.0.0.9 and saw the same error:
              Source File: http://10.1.126.1/zabbix/graphs.php?form=Create+Graph
              I have popups enabled for localhost so I tried allowing all popups and received a similar error message:
              The name "crash" is the label for the hard drive on the test host.
              Thanks.
              • Aly
                ZABBIX developer
                • May 2007
                • 1126
                Make sure that this line is in generated page:
                <script type="text/javascript" src="js/common.js"></script>
                Make sure that this file exists:
                "{path_to_frontend}/js/common.js"
                In that file in line ~142 there should be function named "PopUp" (case sensitive).
                There shouldn't be such problem(just tested it on IE7,FF,OP & Safari 3), may be you got modified frontend..
                • hornet
                  • Nov 2007
                  There was no directory zabbix/php/js. I retrieved a copy of the source files directly from zabbix.com and copied that directory into my working directory which has resolved the problem.
                  Thanks.
