Getting total datatraffic per month
  • RoelofMiddeljans
    • Oct 2007
    I'm working with Zabbix for three and a half month now and I'm having a problem.
    I want to monitor the total datatraffic per month.
    For example:
    Every first day of the month at 0:00 I want to know the difference between the current and the previous value.
    I want to keep an eye on the datatraffic limit of the webhost and be warned when it's getting too high.
    At the moment I use an Userparameter with an item (interval 86400 sec and delta (simple change)) to get the total amount of traffic per day:
    UserParameter=network.traffic.total[*],echo "$((`/sbin/ifconfig $1 |grep bytes|cut -d":" -f2|cut -d" " -f1` + /sbin/ifconfig $1 |grep bytes|cut -d":" -f3|cut -d" " -f1`))"
    Is there a solution to get the total data traffic per month, or is it only possible to do this per day (86400 sec)?
    I know it is possible to work it out with a cronjob and push the value to the server, but I want use only Zabbix for it.
    Thanks,
    Roelof
    __________________
    Using:
    - 1 Host (50 items)
    - Zabbix ver 1.4.2 (for Linux)
  • just2blue4u
    • Apr 2006
    • 347
    great idea!
    This is very interesting for me, too.
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
    • michaeltje
      • Aug 2007
      • 44
      Im interessted aswell!
