Cummulative graph?
  • paddyj
    • Nov 2007
    Cummulative graph?
    Is it possible to create a graph where the items are added together?
    For example I would like to graph memory used, cached and buffered as fill sections but have them summed together so they look like this, displaying the total memory used.
    Is this possible?
  • RoelofMiddeljans
    • Oct 2007
    You can use the "Stacked" option in Graph type instead of "Normal". When you add more then one item, the values of the items will be summed.
    Greetings,
    Roelof
    • paddyj
      • Nov 2007
      Thanks for the reply,
      I only seem to have "Simple" and "Aggregated" in my graph types. Is this a new feature, what version are you using?
      Paddy
      • RoelofMiddeljans
        • Oct 2007
        You are looking at the options of the item in the graph. You can find the option "Graph type" in the option screen of the Graph itself.
        Greetings
        Roelof
        • paddyj
          • Nov 2007
          I didn't have that option, looks like the Debian stable package for Zabbix is quite old 1.1.4.
          I have upgraded to 1.4.1 and can create stacked graphs.
          thanks,
          Paddy
