I have two newbie questions hopefully someone answer for me.
Lets say I have three items for 'server1', we'll call them check port 80 on 'server2' (net.tcp.port[iptoserver2,80])
Now does the ZABBIX server check for that port, or does it make server1 check server2?
Also, that TCP ping to server... is that the zabbix server pinging the agent or vice versa?
The reason I ask is because I had about 10-15 minutes downtime on saturday and haven't seen any drop of availability on those three items for checking port 80. They maintained '1' status since I configured them on thursday. I'm not sure why they kept that status while the machine was off.
EDIT: Also, I just noticed Host Status is all screwned up. I've had it installed since Nov 21st and it one server was restarted on the 24th
Here are the past 500 Latest values for that item
Timestamp Value
2007.Nov.24 06:12:33 Up (0)
2007.Nov.24 06:11:33 Unreachable (2)
2007.Nov.21 11:27:25 Up (0)
2007.Nov.21 11:24:23 Unreachable (2)
Also in the trigger section the status is unknown for those two triggers.
dmzweb1 Server dmzweb1 is unreachable UNKNOWN High 21 Nov 10:58:27 Change -
dmzweb2 Server dmzweb2 is unreachable UNKNOWN High 24 Nov 06:12:33 Change -
Thanks in advance!
Timestamp Value
Thanks in advance!
