Unreachable for > x minutes
  • cbidwell
    • Aug 2006
    • 127
    Is there a way that I can modify this syntax to where if a system is unreachable for x amount of minutes to only alert after that time frame? Say it is unreachable for > 5 minutes only to send out the alert then?
    {Template_Linux:status.last(0)}=2
    Would I say: {Template_Linux:status.last(300)}=2
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    {Template_Linux:status.min(300)}=2
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • cbidwell
      • Aug 2006
      • 127
      Great! Thank you.
      One more question...is there a way that I can get emailed every 5 or 10 minutes and it tell me in that mail how long the system has been unreachable?
      • elvar
        • Feb 2008
        • 226
        I found this very helpful as well. Thank you!
        • vhm3
          • Jun 2008
          • 13
          Most excellent, and thank you!
          Chip
          • elvar
            • Feb 2008
            • 226
            Unfortunately this didn't work the way I thought it would. I would prefer to never receive an alert until any of the unreachables have been unreachable for 5 minutes. After changing the unreachable trigger to status.min with a value of 300 I still was alerted almost instantly.
            Anyone gotten this to work properly?
            • bbrendon
              • Sep 2005
              • 873
              I don't use status item because I personally believe its redundant. What are the values status returns?
              You can then use the function min/max/nodata/etc for number of polls or for a periods of time.
              Unofficial Zabbix Expert
              Blog, Corporate Site
              • elvar
                • Feb 2008
                • 226
                Can you please paste an example of the nodata function syntax to use for this? I only want to be alerted when it receives no data from the zabbix agent after 5 minutes. Right now there are too many false positives when the network blips for very short periods of time.
                • elvar
                  • Feb 2008
                  • 226
                  There is probably a way to do this with functions but I found a solution that works perfectly for my needs. In the /etc/zabbix/zabbix_server.conf I found the following...
                  # After how many seconds of unreachability treat a host as unavailable
                  UnreachablePeriod=300
                  I'd still like to know the way to do this exact same thing with functions per template.
                  Regards,
                  Elvar
                  • jroberson
                    • May 2008
                    • 124
                    This is the trigger I use to tell me when a system is unreachable for 5 minutes:
                    ({Template_Windows:status.last(0) }=2)&({Template_Windows:status.nodata(300)}=1)
