Zabbix + FreeBSD ports + WEB monitoring
  • Ajunne
    • Jun 2007
    • 9
    Hi All,
    I just installed Zabbix and all dependencies via the FreeBSD ports system, works like a charm. However, when I start Zabbix, I keep getting a message that WEB monitoring is disabled:
    23497:20071204:122155 Starting zabbix_server. ZABBIX 1.4.2.
    23497:20071204:122155 **** Enabled features ****
    23497:20071204:122155 SNMP monitoring: YES
    23497:20071204:122155 WEB monitoring: NO
    23497:20071204:122155 Jabber notifications: YES
    23497:20071204:122155 **************************
    Even though libcurl is installed (latest version) and zabbix is compiled with the support built in, as seen in the Makefile from the port:
    CONFIGURE_ARGS= --disable-agent --enable-server \
    --with-net-snmp=${LOCALBASE}/bin/net-snmp-config \
    --with-curl=${LOCALBASE}/bin/curl-config \
    --with-jabber=${LOCALBASE}
    I can add web monitors, activate them, but they do not seem to run, at all.
    What am I missing here?
