Hello, I have a Trigger and and Alarm set to activate when Zabbix agent on a host goes down.
Everything works fine.
The only problem which i cannot get through is, how to restart the Zabbix agent once it is down?
I tried using the remote Command:
{HOSTNAME}:/usr/local/bin/zabbix_agentd
(where the zabbix agent binaries are in: /usr/local/bin/zabbix_agentd)
but it does not work.
any suggestions would be appreciated.
Zabbix server 1.4.2 and Zabbix agent 1.4.1
