hi!
i'm traying to Execute script check in my zabbix agent , i defined in
configuration parameter ExternalScripts, the problem is that my script is in my zabbix agent and it's not supported by zabbix v 1.4.2, however if a Execute script check in my zabbix server that's all ok and the status in zabbix is active.
The question is that i can Execute script check in my zabbix agent? , or how define the parameter ExternalScripts in my cong file?, i can put this in zabbix_agent.cong?.
This is my zabbix_server.conf:
ExternalScripts=/etc/zabbix
Thanks for your help!!! abd sorry for my english i speak spanish!!
