im trying to install Zabbix 1.4.3 on an AIX 5.3 (64bit).
I'm using the same configuration as on Zabbix 1.4.2 but i always get this error:
checking whether libcurl is usable... no
configure: error: Not found Curl library
when I check the logfile I get this:
configure:10385: checking whether libcurl is usable
configure:10430: cc -qlanglvl=extc89 -o conftest -g -I/tools/mysql/includ
e -q64 -ma -qstrict -qoptimize=2 -qmaxmem=8192 -I/zabbix/curl/lib -L/tools/zlib/lib -L/tools/openssl/lib -L/zabbix/curl/lib -L/zabbi
x/net-snmp/lib -static -L/zabbix/curl/lib -L/tools/openssl/lib -L/tools/zlib/lib conftest.c -lm -lcurl -lssl -lcrypto -lz >&5
cc: 1501-210 command option t contains an incorrect subargument
"conftest.c", line 89.10: 1506-296 (S) #include file <curl/curl.h> not found.
"conftest.c", line 97.18: 1506-045 (S) Undeclared identifier NULL.
"conftest.c", line 97.23: 1506-045 (S) Undeclared identifier CURLOPT_URL.
"conftest.c", line 97.35: 1506-045 (S) Undeclared identifier NULL.
"conftest.c", line 98.3: 1506-045 (S) Undeclared identifier CURL_ERROR_SIZE.
"conftest.c", line 99.3: 1506-045 (S) Undeclared identifier CURLOPT_WRITEFUNCTIO
N.
"conftest.c", line 100.3: 1506-045 (S) Undeclared identifier CURLOPT_FILE.
"conftest.c", line 101.3: 1506-045 (S) Undeclared identifier CURLOPT_ERRORBUFFER
"conftest.c", line 102.3: 1506-045 (S) Undeclared identifier CURLOPT_STDERR.
"conftest.c", line 103.3: 1506-045 (S) Undeclared identifier CURLOPT_VERBOSE.
configure:10436: $? = 1
what should / can I do?
N.
