Folks -
I'm using Zabbix Server 1.4.1 on Ubuntu. I'm using it, in part, to monitor some SNMP v1 switches and printers.
The HP printers on my network recognize the hrprinterdetectederrorstate object - in this case, giving information on the state of paper and toner in the system. THe object is described in the docs as such:
Problem is, I can't figure out how to set up a trigger based on this information; I don't quite know how to set up the trigger and/or the item to recognize the hexadecimal values. If I cast the item as a character, the return is a superscript three; if I cast it as a number, Zabbix won't even give me the data.
Does anyone have an idea as to how I could process this value?
Thanks!
This object represents any error conditions detected by the printer. The error conditions are encoded as bits in an octet string, with the
following definitions:
Condition Bit # hrDeviceStatus
lowPaper 0 warning(3)
noPaper 1 down(5)
lowToner 2 warning(3)
noToner 3 down(5)
doorOpen 4 down(5)
jammed 5 down(5)
offline 6 down(5)
serviceRequested 7 warning(3)
Thanks!
