Hi, Im trying to do a script that checks the route to a destination host using a UserParameter in the zabbix_agentd.conf file.
It looks like this:
UserParameter=routecheck[*],/usr/local/zabbix/routecheck.sh
I also have an Item with a key like this:
routecheck[router.test.com]
But when I activate the check I get this in the agent log:
28467:20071221:092823 Run remote command [/usr/local/zabbix/routecheck.sh] Result [57] [Usage: /usr/local/za]...
28467:20071221:092823 Sending back [Usage: /usr/local/zabbix/routecheck.sh <destination host>]
The script needs exactly one parameter to work, if it dosnt get exakly one parameter it will printe the Usage message I see in the log.
Is there some more trick I need to do to get the zabbix_agentd to pass the parameter to the script?
Zabbix 1.4.2
Suse Linux Enterprise Server 10 SP1
It looks like this:
Zabbix 1.4.2
