I uncommented the mysql lines in the zabbix_agentd.conf file, and supplied the proper information. However, when I try to add the metric to a graph, it says that it is "Not Supported." I thought it could be because zabbix did not have a login shell, so I gave it a basic bourne shell. Still did not work, (although running the commands directly from the cmd line did). I thought it might work if I added the Zabbix user to the root group, it might work, but it did not.
Any ideas?
Thanks.
Any ideas?
Thanks.
