import Template Graph does not propagate to host
  • dakol
    • Jan 2008
    • 50
    i want to add a graph (network eth2) to a Template.
    So i used the Export function to export the "eth1 graph", then i replace eth1 by eth2, and Import the file.
    The graph seems to be correctly imported.
    but the host derivated from the Template does not have this new Graph.
    So, i try to add the Graph by hand, clic, clic, clic, and it works
    Did i missed something ?
    thank you,
  • richlv
    • Oct 2005
    • 3112
    seems to be the same as http://www.zabbix.com/forum/showthread.php?t=7985
