Am I smoking crack?
  • Crazy Marty
    • Sep 2007
    • 75
    Am I smoking crack?
    So, I've just created a new template to monitor the latest application rolled out across our web farm, so I want to add that template to all of the hosts in that group. But I don't see a way to do that! Am I missing something here?
  • bbrendon
    • Sep 2005
    • 873
    Please share. I had a rough night, could use a pick-me-up.
    Interesting. I've always done it one by one. Probably because I don't have enough groups to break it down.
    But I think there is a way.
    1. Under configuration -> hosts
    2. Now make sure the drop down of "host templates, host groups, etc", says Templates, and the other dropdown for Group says All
    3. Select the host to add the template to
    4. You'll see a column labeled action. Click the select button next to the Template you want to apply to a group. So its Select -> Add to Group -> Your template
    5. You should be good!
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Crazy Marty
      • Sep 2007
      • 75
      Sigh. No, all that does is make the template a member of the group.
      It sure seems like it would really be desirable to be able to apply a template to a group with 1 click....
      • noxis
        • Aug 2007
        • 145
        Currently you can't, however I have got around this in the past by linking the new template to a template that already exists on the required servers. Failing that a direct database update.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          No, you are not! Templates for WEB monitoring are not supported yet.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • Noobz
            • Jun 2020
            • 105
            Just click on Configuration > Host groups > Hosts > select all > mass update > add the template.
              Holy mother of thread resurrection.... 12 years...
