zabbix db backup
  • n0mad44
    • Jan 2008
    zabbix db backup
    I want to backup my zabbix database... so I've some questions ! I'm monitoring about 20 hosts and "tuned" update intervals of items. I'm keeping history for 365 days. My server is a dedicated zabbix server; cpu is a Xeon 3Ghz and ram is 1 Ghz
    1. I want to do 2 kind of backup :
    - config only (for daily dump)
    - full db (config + trends/history) (for weekly dump)
    Which tables need I to backup for "config only" [or which tables don't I need (-: ]?
    2. Tables are using innodb (as recommended) and I want to do hot backup (without stoping mysql) : is mysqldump the "best" free tool to do it ?
    3. What are the most options to use with mysqldump to quickly generate a dump. I tried a mysqldump today and it took 22minutes for an output file of 2Gb. (do you find it quick/normal/slow according to my configuration?)
    4. Have you some tricks to optimize DB performance ?
    I red some papers around and put theses options in my my.cnf :
    innodb_buffer_pool_size=751M
    innodb_log_file_size=187M
    innodb_additional_mem_pool=8M
    innodb_log_buffer_size=8M
    innodb_flush_log_at_trx_commit=1
    something bad ? something else ? maybe something to add to the crontab to reindex ?
    Thanks for your help,
    n0mad
  • Petya
    • Dec 2007
    • 37
    1) For config only backup you have to backup everything except for:
    - acknowledges
    - events
    - history*
    - housekeeper
    - sessions
    - trends
    (Have I missed something?)
    2) && 3) `mysqldump --single-transcation --quick`
    Another option (which I haven't tried yet) is keeping DB files
    on an LVM volume, make LVM snapshot -- here's binary online backup
    If you succeed with this option -- tell me, I'm much interested.
    4) mysql optimizations depend on your hardware (mostly RAM),
    also database optimizations (their importance) depend on
    items per second your server has to monitor .
    To find how many items per second your server has to monitor
    you can use this patch:
    • n0mad44
      • Jan 2008
      Thanks for your reply, I will test mysqldump options soon (-: Thanks for the patch too....but how to apply it ?
      In fact, I already tested LVM Snapshot and it worked fine...but I needed to stop my mysql daemon (don't remeber why).
      It was a quick shutdown of the DB, but it doesn't was real hot backup !
      To take the snapshot I used "lvcreate --snapshot --size 100 --name save /dev/vg/data" were "/dev/vg/data" was my db location. Then a simple mount (mount /dev/vg/save /mont/point) followed by a tar of the content of the mount point and you have a binary backup!
      Before doing this, your script need to ensure /mount/point is unmounted and you have to remove older snapshot : lvremove -f /dev/vg/save
      ciao
      • Petya
        • Dec 2007
        • 37
        To apply patch:
        1) put zabbix-1.4.4-items_per_second.patch file into directory with report1.php
        2) run `patch -p 3 < zabbix-1.4.4-items_per_second.patch`
        Do not forget to backup your php frontend files
        before applying patch.
        • alfiere
          • May 2008
          • 51
          Any Zabbix devel can confirm that for the 1.6 as well?
          Cheers,
          Alfredo
          • alfiere
            • May 2008
            • 51
            This is an important aspect!
            Please, give us an answer.
            Furthermore I carefully suggest to insert few lines in the documentation.
            Cheers,
            Alfredo
            • Tenzer
              • Nov 2007
              • 316
              Confirm what? Which tables to leave out when doing a DB backup?
              • alfiere
                • May 2008
                • 51
                Exactly.
                Cheers,
                Alf
                • JoelG
                  • Aug 2007
                  • 32
                  Tool to try
                  I am looking into trying http://www.maatkit.org/tools.html, specifically the parallel dump and restore.
                  On my system, a dump only takes about 20 minutes, but a restore now takes over 8 hours (you have tested a restore haven't you?).
                  I plan on dumping my 1.4.5 database for reconversion to 1.6 using these tools in the next week or so. I will update with the findings.
                  • bbrendon
                    • Sep 2005
                    • 873
                    Google around the mysql restore performance topic.
                    You have to issues a few database commands for the restore to go faster.
                    I actually tried googling it and couldn't find it. I found it in our company wiki.
                    <rant>I hate how people blog about things that don't need blogging and their information is so generic and useless I want to DOS their server. </rant>
                    Anyway...
                    echo "SET AUTOCOMMIT=0;"
                    echo "SET FOREIGN_KEY_CHECKS=0;"
                    cat databasedump.sql
                    echo "SET FOREIGN_KEY_CHECKS=1;"
                    echo "COMMIT;"
                    echo "SET AUTOCOMMIT=1;"
                    ) | mysql --user=username --password=password database
                    Unofficial Zabbix Expert
                    Blog, Corporate Site
