Hi
I like ZABBIX very much
For instance the XML import/export of the configurations (Templates,
Hosts, etc.) is very good, not just for sharing but also for
migration of Hosts from one (standalone) Server to another one.
And for backup - it gets even better with version 1.6
Now, we are often asked "What is monitored by ZABBIX ?"
OK, it's easy. Just do an XML-export and use XSLT-FO to convert the result
to PDF, HTML or whatever you want.
For this task it would be nice to have an XML-Schema (or DTD) for
the export format - and a converter, of course.
Even better: Has someone written a converter for this ?
Thanks in advance.
Best regards
Norbert.
Thanks in advance.
Best regards
Norbert.
