Trigger status "UNKNOWN" instead of "ON"
  • Hichhiker
    • Nov 2004
    • 45
    Is there any way to trigger on host availability?
    I have an application I am monitoring (via zapcat) and every time the app is down all monitoring stops, including a simple tcp check. The trigger on tcp check gets value "UNKNOWN" and the host says "Not Available" and as a result the action never performed. I would like to be able to trigger on "unavailable"
    as this really indicates the app is down but I cant seem to find the way.
    Any ideas?
    Thanks.
    -HH
