After upgrading to zabbix-1.4.4-1 All new Hosts I add that will use external scripts will fail. I get error
3042:20080205:111933 Enabling host [192.168.0.10 TESTING]
3042:20080205:112254 Parameter [icmp_ping[]] is not supported by agent on host [192.168.0.10 TESTING] Old status [0]
and that host is using same template as the old hosts thats working.
Just that all new I add cant use external scripts. in 1.4.4
Note: I have around 150 hosts been monitored by external scripts but cant add any new
