Not right version after upgrading
  • elings
    • Mar 2005
    • 16
    Hello !
    I have made an upgrade from 1.1alpha7 to 1.1alpha10 after the install
    instructions, and it went well with no errors.
    But know when i read the Changelog i says that a new item type "log" is
    added in the alpha10 version, but i don't have that in my menu.
    And when a look on the version in the startpage it says "Zabbix 1.1alpha7"
    So i gues i have done something wrong or forgott some step...
    Please Alexei, could you write down a short list of what you should do
    when you upgrade ?
    Thank you in advance !
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Have you copied the newest PHP files from frontends/php?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • elings
      • Mar 2005
      • 16
      OK, i thought i hade done that, but after another copy of the frontend files
      it looks ok.
      Thank you Alexei !
