Monitoring Tivoli Storage Manager with Zabbix
  • parabola
    • Sep 2009
    • 14
    #16
    I've created a shell script to do all this, right now it pulls in 24 data points with appropriate triggers, doing graphs this week, and intend on cleaning up the script and i'll post it when its ready
    • dougbee
      • Apr 2011
      • 68
      #17
      Hi parabola - any update on your script? Just curious!
      • parabola
        • Sep 2009
        • 14
        #18
        Here ya go doug
        • dougbee
          • Apr 2011
          • 68
          #19
          Thanks, parabola! I hope to start using this in our test environment soon. I'll report back!
          • vlam
            • Jun 2009
            • 166
            #20
            Help
            I have the following setup and a small problem.
            Zabbix Server - Zabbix Proxy - TSM Server
            165.234.202.2 - 155.232.210.121 - 155.232.210.61
            When running the following I get:
            Zabbix_Proxy# /usr/local/zabbix/bin/zabbix_sender -z 155.232.210.121 -p 10051 -s Zabbix_Proxy -k tsm.driveload -o 1 -vv
            zabbix_sender [6793]: DEBUG: Answer [{
            "response":"success",
            "info":"Processed 0 Failed 1 Total 1 Seconds spent 0.000033"}]
            Info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000033"
            sent: 1; skipped: 0; total: 1
            the tsm script is running on my proxy
            what am i doing wrong???
            4 Zabbix Frontend Servers (Load balanced)
            2 Zabbix App Servers (HA)
            2 Zabbix Database Servers (HA)
            18 Zabbix Proxy Servers (HA)
            3897 Deployed Zabbix Agents
            6161 Values per second
            X-Layer Integration
            Jaspersoft report Servers (HA)
            • LenR
              • Sep 2009
              • 1011
              #21
              I think the tsm script needs to run on the tsm server.
              • vlam
                • Jun 2009
                • 166
                #22
                Help
                Thanks LenR
                I have tried running the script from the TSM server but get the same response as when I run it from the Proxy server
                X-Layer Integration
                • vlam
                  • Jun 2009
                  • 166
                  #23
                  Help
                  When I run on the TSM server the following I get:
                  dsmadmc -id=admin -pass=admin -dataonly=yes -comma "select count (state) from ddrmedia where location = 'OFFSITE'"
                  I get
                  0
                  X-Layer Integration
                  • LenR
                    • Sep 2009
                    • 1011
                    #24
                    The zsender line
                    -z must be either the zabbix proxy or server for the client.
                    -s needs to be the clinet name that has the item specfied in -k.
                    Sender will fail if info is sent to the zabbix server/proxy not responsible for the client or if the item doesn't exist for the client in -s.
                    You can debug the zabbix_sender line from the command line, when it works then go back to the script.
                    • LenR
                      • Sep 2009
                      • 1011
                      #25
                      I get
                      0
                      That's a TSM question :-)
                      Debug in TSM interactive, if you get a non 0 value there, you script may be getting the return code, not the value.
                      I usually put the TSM command output to a file ( > $file ) then read that, but I have a lot of multi line stuff to process.
                      • vlam
                        • Jun 2009
                        • 166
                        #26
                        Help
                        Hi LenR
                        I get this when I use:
                        -z Zabbix_Proxy
                        -s TSM_Server
                        TSM_Server# /opt/zabbix/bin/zabbix_sender -z 155.232.210.121 -p 10051 -s TSM_Server -k tsm.driveload -o 1 -vv
                        zabbix_sender [4453]: DEBUG: Answer [{
                        "info":"Processed 0 Failed 1 Total 1 Seconds spent 0.000029"}]
                        Info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000029"
                        X-Layer Integration
                        • vlam
                          • Jun 2009
                          • 166
                          #27
                          When running this I do get a return of 0
                          X-Layer Integration
                          • vlam
                            • Jun 2009
                            • 166
                            #28
                            Help
                            Hi Again
                            OK I installed the tsm agent on my Zabbix Proxy and loaded the script on there like in the documentation and enabled the externalscripts function in the Zabbix Proxy Config, also restarted the Proxy. I configured the dsmadmc configuration so that it can speak to my tsm server.
                            When testing the sender:
                            Zabbix_Proxy# zabbix_sender -z localhost -p10051 -s NR1SABCK02 -k tsm.jobs.failed -o 1 -vv
                            I get:
                            zabbix_sender [30513]: DEBUG: Answer [{
                            "response":"succsess".
                            "info":"Processed 1 Failed 0 Total 1 Seconds spent 0.000069"}]
                            Info from server: "Processed 1 Failed 0 Total 1 Seconds spend 0.000069"
                            sent: 1; skipped:0; total: 1
                            So I see it as working.
                            But when adding it to run in the crontab, Zabbix just keeps on telling me TSM no Data
                            Please can someone help me
                            X-Layer Integration
                            • dougbee
                              • Apr 2011
                              • 68
                              #29
                              Can the TSM log be written to by the user that's running zabbix-server? If not, the dsmadmc command will fail and no data gets sent to zabbix.
                              • vlam
                                • Jun 2009
                                • 166
                                #30
                                Do you mean the User that I created on the TSM server that is defind in the script running on the Zabbix Proxy?
                                X-Layer Integration
