I want to monitor a ruby daemon (e.g. ruby script/server production) but this not seems to work with proc.num. I guess, that sth. like proc.num[server] fails, because the value were not found within the known environment paths?!
So I created a new UserParameter in zabbix-agentd.conf that uses pgrep:
UserParameter=ruby.running,pgrep -f server|wc -l
When I test it with 'zabbix_agentd -t ruby.running' it results in [t|2]. But I have __only one__ process! When I run 'pgrep -f server|wc -l' from commandline, I get the correct 1.
What happend here and how can my problem be solved?
Thanks an best regards
Holger
Holger
