Agentd -> My prog -> Sender -> Server
  • safl
    • May 2005
    • 103
    Hello!
    I'm trying to do a a setup where i poll the zabbix_agentd locally on the monitored host with a 'small prog', after polling for data the data will be send with zabbix_sender to the zabbix_server.
    It's sort of an replacement for active checks until they become available in the Win32 client.
    My question is, how to i get connect with my 'small prog' to the the agent? Can i simply open a socket and pass a string and i will get a return? Or how does it work?
    - Simon
  • araw
    • May 2005
    • 31
    Yup, open the socket, dump the full item string plus CR, expect characters back.
    veearreff root # telnet 192.168.200.252 10050
    Trying 192.168.200.252...
    Connected to 192.168.200.252.
    Escape character is '^]'.
    diskfree[/]
    18419140.000000Connection closed by foreign host.
    memory[free]
    4071424.000000Connection closed by foreign host.
    veearreff root #
    Make sure you configure agentd with the Server directive pointed to localhost however, otherwise it'll RST as soon as the socket's been opened.
    • safl
      • May 2005
      • 103
      So getting the "ZBX_NOTSUPPORTED" means that i need to change my zabbix_agentd.conf?
      • araw
        • May 2005
        • 31
        That would be correct.
        If zabbix_agentd doesn't know what you're asking for, it just says it's not supported.
        # telnet host 10050
        Trying x.x.x.x...
        Connected to host (x.x.x.x).
        i_want_random_stuff
        ZBX_NOTSUPPORTED
        • safl
          • May 2005
          • 103
          Hmmm weird behavior...
          when i telnet to a linux host running zabbix_agentd i get a return like:
          Trying xxx...
          Connected to xx.
          version[zabbix_agent]
          1.1alpha10
          if i do the same on a windows host i get:
          Trying yyy...
          Connected to yyy.
          ZBX_NOTSUPPORTED
          Does the windows agent somehow behave differently?
