Web monitoring URL based on host IP
  • Hichhiker
    • Nov 2004
    • 45
    Is there a way to set up Web Monitoring scenarios to use the IP of the current HOST?
    I have a cluster of identical web instances (each with unique IP) and I set up a Template for monitoring them and assigned it to a host for each instance. I would love to set up a web monitoring for the template and have it be applied to each host (I don't think that would work in 1.4) - so I am probably going to setup one instance and then clone it manually - but it would be MUCH easier to do so if I can use the IP assigned to the host as a variable in the URL (URL of http://{HOST}:8080/my/url) - Is this possible or am I out of luck?
    -HH
