I have problem with a template I'm doing for a cisco switch. Once the items have been created and integrated into a template (with an xml import) some properties can't be modified like the type, the key for the snmp ...
I have the same problem with the standard SNMP V2 template integrated into zabbix. I'm using the 1.4.1 version.
How can I solve this ?
Thanks in advance
Thanks in advance
