Monitoring Access Points via SNMP
  • h.o.t.
    • Feb 2008
    Hello Community,
    we want to monitor our Access Points via SNMP and Zabbix but we have a Problem to put all snmpwalk Data into Zabbix - manufactoring all the snmpwalk OIDs and key´s 1:1 is a very stupid work, in my opinion
    Behind is the snmpwalk output (summed up with grep) - already it´s the same Access-Point, but´s there are different outputs.
    Our idea is, to pick some of these SNMPv2 outputs and sum up, e.g.
    Serialnumber, Attachtype, Name, IP-Address, MAC-Address, Software-Release and so on.
    Has anybody a tipp or an idea how we can sum up the reasonable information?
    Thanks in advance!!
    Greetnx from germany,
    h.o.t. aka Christian
    -----snip-----
    linux /usr/local# snmpwalk <IP> -c <COMMUNITY> -v 1 .1.3.6.1.4.1.14525.4.5.1.1.3.1 | grep '.0.11.14.88.134.0'
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.2.0.11.14.88.13 4.0 = STRING: "0772800269"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.3.0.11.14.88.13 4.0 = INTEGER: 1
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.4.0.11.14.88.13 4.0 = Gauge32: 3
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.5.0.11.14.88.13 4.0 = INTEGER: 7
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.6.0.11.14.88.13 4.0 = STRING: "MP-372"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.7.0.11.14.88.13 4.0 = ""
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.8.0.11.14.88.13 4.0 = STRING: "AP03"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.9.0.11.14.88.13 4.0 = ""
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.10.0.11.14.88.1 34.0 = IpAddress: 0.0.0.0
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.11.0.11.14.88.1 34.0 = Gauge32: 1997383
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.12.0.11.14.88.1 34.0 = STRING: "Atheros:MIPS32 speed=220000000 Hz version=AR5312"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.13.0.11.14.88.1 34.0 = STRING: "Trapeze"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.14.0.11.14.88.1 34.0 = Gauge32: 16777216
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.15.0.11.14.88.1 34.0 = STRING: "G"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.16.0.11.14.88.1 34.0 = Gauge32: 0
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.17.0.11.14.88.1 34.0 = STRING: "REL_6.0.5.1.0_113007"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.3.1.18.0.11.14.88.1 34.0 = STRING: "REL_6.0.5.1.0_113007"
    -----snip-----
    linux /usr/local# snmpwalk <IP> -c <COMMUNITY> -v 1 .1.3.6.1.4.1.14525.4.5.1.1.2.1 | grep .10.48.55.55.50.56.48.48.50.54.57
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.2.10.48.55.55.5 0.56.48.48.50.54.57 = Hex-STRING: 00 0B 0E 58 86 00
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.3.10.48.55.55.5 0.56.48.48.50.54.57 = INTEGER: 1
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.4.10.48.55.55.5 0.56.48.48.50.54.57 = Gauge32: 3
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.5.10.48.55.55.5 0.56.48.48.50.54.57 = INTEGER: 7
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.6.10.48.55.55.5 0.56.48.48.50.54.57 = STRING: "MP-372"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.7.10.48.55.55.5 0.56.48.48.50.54.57 = ""
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.8.10.48.55.55.5 0.56.48.48.50.54.57 = STRING: "AP03"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.9.10.48.55.55.5 0.56.48.48.50.54.57 = ""
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.10.10.48.55.55. 50.56.48.48.50.54.57 = IpAddress: 0.0.0.0
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.11.10.48.55.55. 50.56.48.48.50.54.57 = Gauge32: 3566666
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.12.10.48.55.55. 50.56.48.48.50.54.57 = STRING: "Atheros:MIPS32 speed=220000000 Hz version=AR5312"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.13.10.48.55.55. 50.56.48.48.50.54.57 = STRING: "Trapeze"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.14.10.48.55.55. 50.56.48.48.50.54.57 = Gauge32: 16777216
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.15.10.48.55.55. 50.56.48.48.50.54.57 = STRING: "G"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.16.10.48.55.55. 50.56.48.48.50.54.57 = Gauge32: 0
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.17.10.48.55.55. 50.56.48.48.50.54.57 = STRING: "REL_6.0.5.1.0_113007"
    SNMPv2-SMI::enterprises.14525.4.5.1.1.2.1.18.10.48.55.55. 50.56.48.48.50.54.57 = STRING: "REL_6.0.5.1.0_113007"
    -----snip-----
