SimpleCheck Problem
  • patrick
    • Oct 2004
    • 57
    SimpleCheck Problem
    I would like to use SimpleCheck with icmpping and icmppingsec with different hosts (Cisco, XP) but it never works. Last check/Last value/Change always show "-"
    This is my conf for "Item" :
    Description : icmpping
    Host : myhostxxx
    Type : Simple check
    Key : icmpping
    Status : monitored
    Type of information : Numeric
    Store Value : As is
    And my conf for "Host" :
    Host : myhostxxx
    Use IP address
    Port : 161
    Status Monitored
    What is wrong?
    Thanks in advance
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Welcome, Patrick!
    Do you have program fping installed? It is not part of ZABBIX distribution.
    Is location of fping correctly configured in zabbix_suckerd.conf? Does the program have execute permissions for user zabbix? You may also want to set SUID flag for the binary (+s).
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • patrick
      • Oct 2004
      • 57
      Thank you very much. Now Simple checks icmpping and icmppingsec work.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Note that icmppingsec returns seconds, not mseconds! It is somewhat confusing, especially when you start looking at graphs
        Alexei Vladishev
        My Twitter
