Monitoring NAS device
  • fredfire
    • Feb 2008
    • 13
    Hi all,
    I am trying to find a way to monitor my NAS terastation pro.
    Since I can't install an agent on it, is there a way to monitor shared folder?
    All I need to to monitor the disk space on the units.
  • fredfire
    • Feb 2008
    • 13
    Does anyone have ideas?
    • xs-
      • Dec 2007
      • 393
      Assuming this thing has a network cable, have you tried using snmp?
      You;d have to lookup or snmp walk the device to get the correct oids for the storage volumes.
      another option is to mount the shares on a server and run an agent on it and use the disk usage checks in the agent.
