values in alert message not working
  • bill.unger
    • Jun 2007
    • 79
    Probably a simple question, but I have this defined in the message body of an Action (fired from a trigger):
    {{ HOSTNAME}:{TRIGGER.KEY}.last(0)}
    Unfortunately, the message of the email contains the above literal literal string. Am I missing something?
    tia,
    Bill
  • trikke
    • Aug 2007
    • 140
    Hi Bill,
    works for me, but maybe the "blank" in front of the HOSTNAME is not alowed???
    What Version are u on? I think not all keywords are allowed for versions before 1.4.x ( though documented)
    Greets
    Patrick
    • bill.unger
      • Jun 2007
      • 79
      Originally posted by trikke
      Version are u on? I
      Patrick
      I am running v1.4.4
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        tia,
        Bill
        You may try to get rid of the spaces to make it work.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • bill.unger
          • Jun 2007
          • 79
          I am using the triggers to monitor the windows event log and unfortunately, I can't get the triggers to fire again and test my changes... <sigh> I have created a scenario that forces errors into the event log, but the trigger won't fire... any thoughts?
          Is it me or is Zabbix monitoring and triggering of the EventLog a little picky?
          tia,
          B
