CPU Monitoring on Unix AIX
  • shammari
    • Sep 2004
    Hi
    I just installed zabbix alpha 10 server in Sun Solaris 9 and the agent in AIX 5.2
    I am trying to monitor the CPU of the AIX box using zabbix agent but it say it is not supported.
    Any one can help?
    020913:20050608:184000 Parameter [cpu[idle1]] is not supported by agent on host [xx]
    020913:20050608:184500 Parameter [cpu[idle5]] is not supported by agent on host [xx]
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It's perfectly in sync with ZABBIX documentation! Good news is that 1.1alpha11 will feature support of system[procloadX] under AIX.
    Meanwhile you may use UserParameters to define your own processing.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
