simple trigger question
  • Villain
    • Aug 2006
    • 84
    I want to find out if during the last 10 times a value was found, any of those values were over 5. Can I do this with the following:
    {server:item.check.last(#10)}>5
    I believe this is correct, but I am not sure. I don't want the trigger to fire unless anytime in the last 10 checks, the value was over 5.
    Thanks.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    {server:item.check.min(#10)}>5
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Villain
      • Aug 2006
      • 84
      thanks for the quick answer.
