Is possible set this trigger?
  • DeXTeR-ITA
    • Dec 2007
    • 22
    Hi all!
    Another question...
    I explain what I do, in crontab I put this line, run this script every 10 min.:
    0,10,20,30,40,50 * * * * /share/archivio/datedvd.sh "Colunga V1" /share/archivio/cfc/ cfc
    The script is this, return 2 value for 2 zabbix item (date & time):
    #!/bin/sh
    # datedvd.sh
    # Versione 1.0
    # Autore: Lorenzo Giandomenico
    # Date: 07/03/08
    # Ultima revisione: 14/03/08 Alessandro Bagalini
    # Script per il controllo data ed ora dell'ultimo dato dei DVD.
    # All'avvio dello script e' necessario specificare l'host, il percorso
    # di partenza e la banca dati che si vuole controllare
    # Es: ./datedvd.sh /share/archivio/cfc/ cfc
    # La banca dati deve corrispondere alla chiave settata su Zabbix
    HOST_CF=$1
    DIR=$2
    BANCA_DATI=$3
    cd $DIR
    for i in $( ls -d yd*); do
        YDIR=$i
    done
    for i in $( ls -d $YDIR/md*); do
        MDIR=$i
    done
    for i in $( ls $MDIR/*.dvd); do
        FILE=$i
    done
    DATA=`head $FILE --lines=7 | tail --lines=1 | awk -F '=' {'print $2'} | awk {'print $1'}`
    ORA=`head $FILE --lines=8 | tail --lines=1 | awk -F '=' {'print $2'} | awk {'print $1'}`
    # echo $HOST_CF $DIR $DATA $ORA
    zabbix_sender -z 172.23.0.35 -p 10051 -s "$HOST_CF" -k datedvd.$BANCA_DATI -o $DATA
    zabbix_sender -z 172.23.0.35 -p 10051 -s "$HOST_CF" -k timedvd.$BANCA_DATI -o $ORA
    In zabbix I configure the items in this way:
    Description: DVD CFC Date
    Type: ZABBIX agent (active)
    key: datedvd.cfc
    Type information: Character
    Show value: As Is
    Description: DVD CFC Time
    key: timedvd.cfc
    Show value: As Is
    After a little work is fine, the result in zabbix is:
    YYYYMMDD
    HH:MM
    Es.:
    20080314
    15:30
    But now I miss only one thing, create a trigger for this two items.
    For the date, trigger ON if no change evary 24h, better if different from today's date. And for time if it is different from time is 15 minutes.
    If I explained evil ask please, thank you in advance.
  • bbrendon
    • Sep 2005
    • 873
    For zabbix_sender I think they type is zabbix trapper, not active.
    I didn't understand the trigger question very well.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • DeXTeR-ITA
      • Dec 2007
      • 22
      Ok, I made some changes to the script, now collect the time in format UNIXTIME.
      Script:
      #!/bin/sh
      # datedvd.sh
      # Versione 1.0
      # Date: 07/03/08
      # Ultima revisione: 17/03/08 Alessandro Bagalini
      # Script per il controllo data ed ora dell'ultimo dato dei DVD,
      # convertendo la data in UNIXTIME (secondi a partire dal 1970/01/01 00:00)
      # All'avvio dello script e' necessario specificare il percorso
      HOST_CF=$1
      DIR=$2
      BANCA_DATI=$3
      cd $DIR
          YDIR=$i
      done
          MDIR=$i
      done
          FILE=$i
      done
      YYYY=`head $FILE --lines=7 | tail --lines=1 | awk -F '=' {'print $2'} | awk {'print $1'} | cut -c1-4`
      MM=`head $FILE --lines=7 | tail --lines=1 | awk -F '=' {'print $2'} | awk {'print $1'} | cut -c5-6`
      DD=`head $FILE --lines=7 | tail --lines=1 | awk -F '=' {'print $2'} | awk {'print $1'} | cut -c7-8`
      UNIXTIME=`date -d "$MM/$DD/$YYYY $ORA" +%s`
      ## echo Host CF $HOST_CF - Directory  $DIR - Data $DD/$MM/$YYYY - Ora $ORA - Unixtime $UNIXTIME
      zabbix_sender -z 172.23.0.35 -p 10051 -s "$HOST_CF" -k datedvd.$BANCA_DATI -o $UNIXTIME
      The data collected is fine, but have an error at the end of page "Overview" (repeted 6 time):
      date() expects parameter 2 to be long, string given[/usr/share/zabbix/include/config.inc.php:410]
      What about this error?
      I changed Type of Item in Zabbix Trapper, of course.
      • DeXTeR-ITA
        • Dec 2007
        • 22
        Resolved, the error was due to old incorrect data.
        And finaly I set the Items:
         Type: ZABBIX trapper
         key: datedvd.cfc
         Type information: Numeric (integer 64bit)
         Units: Unixtime
         Show value: As Is
        Trigger fire if the date is 30 min old:
        {Template_CF-DVDControl:datedvd.cfc.fuzzytime(1800)}#1
        I am pleased!
