Just wondering if Zabbix supports more than one item in an arithmetic expression. I'm looking to do the following...
{HOST1:filesize[C:\fileone.dat].last(0)}+{HOST1:filesize[C:\filetwo.dat].last(0)}-{HOST2:syslog[exchws].last(0)}>16000000000
I get ERROR:Invalid trigger expression when I try to add it.
I'm trying to monitor the size of a Microsoft Exchange database, which requires the size of two files to be added together and then the whitespace in those files to be subtracted. So, DBFile1 + DBFile2 - WhiteSpace.
As you can see, the whitespace value is actually retrieved from another host, so is that maybe the problem? Or can I not have three items in a trigger expression?
I can get it to work this way:
((DBFile1 + DBFile2)>16000000000)&(Whitespace<100)
But this isn't ideal... I'd rather track the actual size.
Any thoughts?
Any thoughts?
