I actually sent a PM to you last week, but they are easy to miss on this board, and I thought that maybe others might have similar questions, so I'm posting here.
It seems to work well. The results are different than what I was getting with icmppingsec, which is of course expected.
However, it seems to leave gaps with NO data sometimes. icmppingsec would populate a zero, which I wasn't sure I was happy with, since I wasn't sure if it counted those values for averaging. (I have a trigger that fires if it's >300ms average over 15 minutes.)
However, I'm not sure whether to think that these gaps when using the script represent periods of time where no response was received, or some other problem. What would you expect to be true?
Also, as I'm somewhat of a novice with Linux, I went to look up the Linux ping switches to see if there were any options that might favorably alter this behavior. Far be it from me to criticize (since the pings do seem to work), but it LOOKS to me like -i is to specify the interface, and -I is to specify the interval.
Is it just undocumented that you can put the interval in before the address, after the -i switch?
Thanks, and I'm really just curious, not trying to second guess your scripting.
