Cannot logged
  • ksm451
    • Jun 2005
    • 9
    Cannot logged
    I've install on Ubuntu warty 4.0 and everyting configured except mysql,which was not compile because there was no mysql-dev files in the ubuntu installation.
    When i tried logging into the web interface,using admin without password,I get error messages,login failure,whatever user i put with or without password,i get the same result.pls,Can someone give me a clue,though i used a root password whiles creating the zabbix database.
    thanks
  • sinda
    • Apr 2005
    • 33
    hello,
    you have to install mysql devel. then execute ./configure -with-mysql -with-net-snmp. (follow the manual installation , it will help you)
    mysql devel will solve your problem.
    good luck
    • Neo
      • Jun 2005
      • 59
      did this work?
      I am facing the same problem, I have installed mysql-devel though.
      • Neo
        • Jun 2005
        • 59
        BTW what do the 'd41d8cd98f00b204e9800998ecf8427e' stand for in the data.sq l files.
        INSERT INTO users VALUES (1,'Admin','Zabbix','Administrator','d41d8cd98f00b 204e9800998ecf8427e');
        INSERT INTO users VALUES (2,'guest','Default','User','d41d8cd98f00b204e9800 998ecf8427e');
        I think the problem is with the OLD_PASSWORD and new PASSWORD() functions in MySQL. So if I know what those stand for I could try an UPDATE with the OLD_PASSWORD() function.
        • mconigliaro
          • Jun 2005
          • 116
          taken from: http://www.zabbix.com/manual/v1.1/config_initial.php
          "Enter the username Admin and leave the password field empty."
          • Neo
            • Jun 2005
            • 59
            I did that but am still not able to login.
            Is there anything else that can be done?
            • Neo
              • Jun 2005
              • 59
              SOLVED: see link
