Maps: icons missing
  • sean
    • Mar 2008
    • 28
    Maps: icons missing
    I'm new to zabbix and have installed 1.4.1 on Ubuntu 7.10 (the latest table releases).
    My first Q is when Adding items to a map, I get the errors:
    * Warning. Field [iconid_off] is mandatory
    * Warning. Field [iconid_on] is mandatory
    * Warning. Field [iconid_unknown] is mandatory
    The icon drop down menu options are empty.
    I searched the forums and manual for iconid_off, but didn't find anything.
    On configurations -> general -> Images, I see a place where icons could be added, but am unsure where to go looking?
    Thanks in advance,
    Sean
  • xs-
    • Dec 2007
    • 393
    When creating the database you are supposed to insert 3 sql files
    schema.<db>
    data.sql
    images.sql
    the last one provides the icons afaik.
    • sean
      • Mar 2008
      • 28
      Hmm. Its probably a problem with the debian install scripts then.
      I can add icons one by one from the GUI, but its very slow.
      (found a nice set on icons on http://www.zabbix.com/wiki/doku.php?...:icontemplates)
