trigger in a trigger, possible ?
  • leo.leroy
    • Apr 2008
    Hi ! Got a trigger trouble.
    I'm monitoring a backup server ( bacula ) :
    Before each backup, i have this item updated by zabbix_trapper :
    - "Kind of backup if running" ; possible value = 0 (nothing), F (Full backup in progress), I (Incremental...'gress ), D ( Differential )
    After each backup, i have these items updated :
    - Duration of last Full backup ( unit Min, could be in Sec )
    - Duration of last Incremental backup ( unit Min, could be in Sec )
    - Duration of last Differential backup ( unit Min, could be in Sec )
    - Result code of last backup ( 0 or 1 for error )
    - Kind of backup if running ( 0 which apply for "none in progress" )
    I explain the trouble :-)
    I already have a trigger on the backup_template :
    {Backup_template:bacula.backup.result.last(0)}=1
    It is the "Result code of last backup" : 1 = trigger on
    So i'd like to know now if a backup is abnormally long.
    I thought of this scheme :
    "last value for Kind of backup if running" not equal "0" and "Kind of backup if running has received no data for more than 150% the average time it took for the last ten values received regarding the same kind of backup"
    Ok let me say : It's a trigger in a trigger !
    It could be 3 triggers ( one for abnormally long Full Backup is in progress, one for Incremental and the last for Differential )
    Example for the "abnormally long Full backup is in progress" :
    {Bacula_template:bacula.backup.status.str(F)}=1&{B acula_template:bacula.backup.status.nodata(({Backu p_template:backup.duration.full.avg(#10)})*1.5)}=1
    But it simply don't work w/ err : [#10)})*1.5] is not a float or counter for function (avg)
    Can someone help me to fix this please ? :-)
  • tekknokrat
    • Sep 2008
    • 140
    Did you managed your problem?
    I also want to monitor our bacula setup. Do you have a template to share?
