Just want to be sure I'm understanding something correctly -
What exactly is the difference between these two items?
SSH server is down on {HOSTNAME}
Sshd is not running on {HOSTNAME}
I'm seeing the message below over and over on my UNIX hosts I'm monitoring w/ Zabbix.
sshd[21726]: [ID 800047 auth.crit] fatal: Read from socket failed: Connection reset by peer
I thought I read somewhere the zabbix agent is disconnecting too quickly or something, not cleanly exiting w/ these messages as the end result???
Should I disable these items in the host checks, and check if ssh is running from the server w/ a simple check rather than w/ the agent?
thanks in advance
thanks in advance
