ping simplecheck
  • tlethuillier
    • Jun 2005
    ping simplecheck
    I want use icmpping in simple check and zabbix doesn't excute the item.
    I have configured the file /etc/zabbix/zabbix_sucker.conf to find fpinger.
    I don't know if zabbix doesnt create /tmp/zabbix_suckerd.pinger or if i have a problem witch the command:
    cat /tmp/zabbix_sucker.pringer | fpinger -e
    Help me.
    Thank you
  • mconigliaro
    • Jun 2005
    • 116
    chmod +s /usr/sbin/fping
