upgrade to 1.4.2.
  • fluque
    • Sep 2007
    • 9
    upgrade to 1.4.2.
    Have I Debian with Zabbix 1.4.1, to update to the version 1.4.2, that I must follow(continue) steps?
    That I command to use to install the package 1.4.2?
  • bbrendon
    • Sep 2005
    • 873
    This command will update your zabbix to the latest available for you version of debian:
    apt-get update; apt-get install zabbix-server-mysql
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • bigZabbixnoob
      • Feb 2008
      Hi. I'm using Ubuntu 6.06. Is there a way I can easily upgrade from zabbix-1.4.4 to zabbix-1.5? Does that command simply upgrade to the latest zabbix available -- or does it upgrade to the latest stable version? I'm looking to test out 1.5 while we wait for 1.6 =)
      • bbrendon
        • Sep 2005
        • 873
        Stable -> beta isn't designed to be easy. I think the proper term is YMMV. Good luck
