Min Max Functions
  • shohn
    • Apr 2007
    • 21
    Min Max Functions
    I'm trying to create a bit of hacked up escalation on some of my triggers. I've tried all sorts of different combinations of min, avg, and max for when a server goes unavailable.
    Basically I'm trying to create triggers based on the amount of time a host has become unavailable. Something like this ->
    Warning
    {Template_Windows:status.min(120)}#0
    Average
    {Template_Windows:status.min(300)}#0
    High
    {Template_Windows:status.min(600)}#0
    Disaster
    {Template_Windows:status.min(1200)}#0
    Please advise!
    Thanks,
    Shohn
  • xs-
    • Dec 2007
    • 393
    For starters, you might want to make them {Template_Windows:status.max(120)}#1 (if 0 is down and 1 is up)
    This way the trigger will be active when the server is down for 120s.
    I'd also make them dependant on eachother
    • shohn
      • Apr 2007
      • 21
      It Doesn't work
      It seems like the first 2 minute trigger works just fine.
      I disable the zabbix agent as a test.
      I'll get a message that warns that the host is unreachable for 2 minutes, but no messages for 5 minutes, 10 minutes, and so on. Once I renable the zabbix agent and I get messages back that the server is now available for , 2, 5,10, and 15 minutes.
      Is there something I am not understanding about the min and max functions?
      • shohn
        • Apr 2007
        • 21
        Solution located
        I just used graduating instances of the following and it works.
        {Template_Windows:agent.ping.nodata(28800)}=1
        Max and min only works for the first event triggering.
