Exchange perfcounter NOT SUPPORTED?
  • Hotzenwalder
    • Apr 2008
    • 11
    I'm trying to monitor the remote queue lenght of an Exchange server (Exchange 2003) but after adding the item Zabbix says 'not supported'.
    The item is: perf_counter[\SMTP Server(_Total)\Remote Queue Lenght] (type = numeric float)
    When running the check from the commandline:
    zabbix_agentd.exe -t perf_counter["\SMTP Server(_Total)\Remote Queue Lenght"] -c zabbix_agentd.conf
    The response is: perf_counter[\SMTP Server(_Total)\Remote Queue Lenght] [m|ZBX_NOTSUPPORTED]
    This is the way it is called in the performance monitor on windows. I have several other items running against the Exchange server which work fine. Why does Zabbix respond with 'not supported' on some performance monitor keys and how can I fix this?
  • swaterhouse
    • Apr 2006
    • 268
    Spelling counts! (see bold correction)
    perf_counter[\SMTP Server(_Total)\Remote Queue Length]
    • Hotzenwalder
      • Apr 2008
      • 11
      I will now hide in the corner out of shame...
      Do all performance counters that are available on Windows work with Zabbix (when using the correct spelling?)
      • bbrendon
        • Sep 2005
        • 873
        Yes, they all work!! ...BUT some of them you need a running average to get any useful values.
        Unofficial Zabbix Expert
        Blog, Corporate Site
